89 yj om617 high rpm shake and clicking noise at idle
Old Dec 12, 2014 | 10:45 AM
dutchsupreme's Avatar
Default 89 yj om617 high rpm shake and clicking noise at idle
So I have successfully installed the om617 in my yj with a couple issues.
Two questions, why is there a clicking noise from my transmission. At first I thought it was the exhaust gasket leaking making that clacking noise but after replacing it there was no change.
The noise is coming from the clutch area. I did install a new clutch flywheel pressure plate and throw bearing when I did the swap.
Second why when I hit higher rpm it shakes but only under load. If I have the engine rpm increase with no load no shake...
I used the adapter from Metered 4x4 however I did not get the new yj flywheel balanced. Could this be my issue?
Old Dec 12, 2014 | 10:49 AM
I guess I should put this under the right category... Sorry
Old Dec 14, 2014 | 11:00 PM
97cummins's Avatar
Welcome to db
Old Dec 18, 2014 | 01:44 PM
1ATony's Avatar
Thanks for joining.
Tony
dutchsupreme
Diesel Engine Conversions
Dec 13, 2014 12:26 PM
