need help with 6.5
Old Dec 9, 2014 | 04:28 PM
jdfcc's Avatar
Default need help with 6.5
first time posting hope someone can help,98 chevy 3500 6.5 all stock engine dies when coolant temp reaches 170 deg and cannot get tdc offset to reset timing is running 15 deg tdc shows 2.46 will not reset to 0 with procedure pump was replaced
Old Dec 10, 2014 | 03:29 PM
Mayhem's Avatar
jdfcc I have moved your thread to the 6.2/6.5 section to get more views to get your issue resolved a little quicker.
Old Dec 11, 2014 | 11:25 AM
jdfcc's Avatar
just replaced injector pump has new pmd
Old Dec 11, 2014 | 11:55 AM
racer55's Avatar
The IP is out of spec and will have the corresponding trouble code.
First you will need to rotate the IP towards drivers side fender about 3mm,clear codes and then do relearn procedure with coolant 170f+ as often as needed to get in spec.
You are not looking to get TDCO to be 0,it should be -.25 to -.75 for stock spec or -1.5 to -1.94 for performance spec.
airspeed181
Jan 19, 2015 09:00 PM
Levis95
Jan 11, 2015 01:54 AM
Snoobly
Dec 11, 2014 11:59 AM
bdemutis
Dec 7, 2014 01:36 AM
bdemutis
Nov 28, 2014 08:16 PM
