Y pipe leak?
Old Dec 9, 2014 | 02:42 PM
CodyC's Avatar
Default Y pipe leak?
OK....first post and I am somewhat of a noob. I have a 2006 power stroke. I just got a SCT livewire 4 in turbo back exhaust , egr delete, headstuds, oil cooler, a 2003 turbo and a coolant filtration system less than 500 miles ago. Everything running great with an insane whistle from the 03 turbo. Going down the road at 65mph and the whistle is gone....start checking gauges and everything is good but not building boost at low rpm...under 1800rpm. Vgt duty cycle ranges from .14 at idle to .47 at 25psi which is about all I can push now....was getting about 32psi full boost. Slight exhaust fumes in cab occasionally. Real throaty exhaust sound now and I am pointing towards the ypipe being cracked....any advice to confirm my thoughts
Thanks in adavance
Old Dec 9, 2014 | 02:44 PM
CodyC's Avatar
And it is not throwing any codes
Old Dec 9, 2014 | 03:48 PM
Adrenaline junkie's Avatar
Makes sense to me. . Check for stuck vanes if you have used turbo
Old Dec 9, 2014 | 03:52 PM
CodyC's Avatar
Brand new turbo....thanks for the advice
Old Dec 10, 2014 | 04:09 PM
Check your fuel pressure, and high pressure oil, actual not expected. . .when my HPOP was going I lost power and whistle less ( I have 03 whistler I love!)
Devon7.3
Sep 28, 2015 09:30 PM
IHdude
Chevy/GMC Duramax 01-04 LB7
Jul 12, 2015 11:14 PM
InheritedDiesel
Jun 3, 2015 09:39 PM
ash23k
Dec 30, 2014 08:31 PM
Dec 5, 2014 08:30 AM
