Replacing input rod seals on hydroboost
Old Dec 9, 2014 | 09:55 AM
woodsman27's Avatar
Default Replacing input rod seals on hydroboost
Finally got around to pulling the hydroboost on the old beast and it looks like my input rod seals (on the input rod and piston assembly) are leaking pretty bad. The pedal rod that attaches to the assembly is staked (will need to be cut to replace the seals) and I was wondering if anyone has come across someone who sells a replacement? Or has anyone cut the shaft and just customized it to make it work?
