converting to p pump
Old Dec 6, 2014 | 05:47 PM
Shawnsr1's Avatar
Default converting to p pump
I have A 2001 24 valve cummins the ecm is bad and I'm thinking about converting to a p pump . I need to know what parts I need for the convertion .I have some access to some older 12 valve motors.
Old Dec 11, 2014 | 04:52 AM
gh0stman's Avatar
Here is a list of parts needed to do a p-pump conversion...VP44 to P7100 Injection Pump Conversion Parts
Old Dec 13, 2014 | 09:30 AM
99dodge's Avatar
I did a P-Pump the 913, 215hp is the better pump. If you can get one thats the way to go.
Old Dec 13, 2014 | 09:43 AM
99dodge's Avatar
Default Rocker arm galling
I also found a way to fix rocker arms that have galling inside them and the pivot shafts that get scored up. This happens Do to lack of oil at the rockers themselves, and also having a bigger cam and valve springs. The OEM rockers can't handal the extra stress. Plus if you have 4k gov spring kit the added rpm's don't help either. But I fixed that I did't have to spring for $1800.00 Harland Sharp rockers etheir.
Back-in-Black
Chevy/GMC Duramax 01-04 LB7
8
Aug 13, 2017 10:35 PM
landon025
Sep 8, 2015 09:21 PM
HardLuck
Jun 24, 2015 08:04 AM
greenbomb
Jan 23, 2015 10:36 PM
B.k. Smith
10
Jan 7, 2015 02:29 PM
