recabbing 99 dodge with cummins
Old Dec 5, 2014 | 10:59 AM
ZGT's Avatar
ZGT
Default recabbing 99 dodge with cummins
was wondering if anyone can give me info on what I need to keep off 99 dodge cab chassis, when I put on a 40 international cab
wondering as far as electrical.
thinking I may intergrade dash and steering column into IH cab.
thoughts from anyone please
Old Dec 8, 2014 | 10:16 PM
Baradium's Avatar
If you convert to a mechanical pump from the vp44 it'll make it a lot less complicated, but if you want the full electronic suite for the engine... there's going to be a lot you'll positively have to keep. I've never done anything like that so this is all speculation. I guess I'd start with removing the whole wiring harness and everything it attaches to and removing the items that aren't needed from that piece by piece. There are so many little bits that you'll need for the electronics to work right there.
Which cab are you actually using? Light/medium?
Old Dec 9, 2014 | 07:15 AM
ZGT's Avatar
ZGT
1940 DS-30 cab is what I am using
Old Dec 11, 2014 | 09:46 PM
Truck Guy99's Avatar
Post pics when you start the build. If your dead set on keeping it all electronic then follow baradiums advice. My advice is p pump it. Less electronic stuff, easier to get power out of, etc.
Old Dec 15, 2014 | 05:15 AM
gh0stman's Avatar
If you are keeping the current setup, ie VP44. You might as well use the electrical bits already on the truck. Pretty much the truck will be thinking dodge while it has been "re-skined".
Josh Chretien
5.9L 12V Performance
Mar 1, 2015 06:00 AM
Linkbeltpower
For Sale
Dec 16, 2014 08:44 AM
Linkbeltpower
For Sale
Dec 15, 2014 10:52 PM
Nov 4, 2014 08:10 AM
kamwil54
Nov 2, 2014 08:48 PM
