10 or 100 fuel plate.
Old Dec 2, 2014 | 05:56 AM
Whitereaper12v's Avatar
Default 10 or 100 fuel plate.
I'm running some pretty big injectors and I have no fuel plate in my truck. I want to try and tame the egts to make them manageable. It rockets past 1200 degrees without a care. It's making around 35 lbs of boost. I'm also ordering a 4k gsk and valve spring should I get different retainers?
Old Dec 2, 2014 | 07:11 AM
wpg6.5's Avatar
Cut the plate to a 100 or 0 or somewhat of a custom hybrid version. Put it back in and tune it properly. And as for retainers that's your call, for the price of titanium retainers I would just buy hamiltons 165 spring kit that comes with retainers and all that for 550$ instead of like 200 for retainers and 150 for 60lbs. Wish I had done that in the first place.
Old Dec 2, 2014 | 11:03 AM
cummins Pride's Avatar
I run a #0 full forward on my stock turbo with my other mods in my sig and my egts are about 800 cruising 75-80mph even on a 7in lift on 37s
Old Dec 2, 2014 | 11:14 AM
My truck goes way about 1200 degrees. Besides injectors what else could cause this. Could too much boost blowing hot air cause this? It doesn't feel like a lose of boost. The truck has plenty of go. It's just the temp that's the problem. I never took the fuel plate out my self but by the way it's acting I am guess it's the fuel plate.
Old Dec 2, 2014 | 11:34 AM
wpg6.5's Avatar
What's your set up? Turbo, injectors, dv's etc. Afc tuning has a huge play and no plate has a huge affect. Nothing wrong with 1200, I probably hit 1700 on the dyno and before I tuned it totally properly I could hit 1500 all day. Get a plate in a tune it proper.
Old Dec 2, 2014 | 04:45 PM
I have no idea how big they are. I'm going to try and figure out next time I come into town. Right now I'm at a duty station. I let off at 1200 because it will climb right past it. My father drove the truck a week ago took a video that shows the boost level and Pyro levels. I'll get him to email the video and I'll upload it to YouTube tonight.
Old Dec 3, 2014 | 10:03 PM
if you are still running a stock turbo thats your problem right there, big injectors,dvs,and no fuel plate is a lot of fuel for the low amount of air the hx35 can pull in.
Old Dec 11, 2014 | 10:04 AM
BIGRED12V's Avatar
what size injecotrs? i am looking at getting 7x.010 by CPP or DAP, and i have mods listed in signature. Would that run to hot or could i get by without a bigger turbo?
Old Dec 22, 2014 | 10:22 PM
jkidd's Avatar
If you are running stock turbo consider our 5x.011 SAC. You will be happy. our 7x.010 or 5x.012 will be too much fuel for the stock turbo with your other mods.
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
SMatyac
Nov 15, 2014 07:35 PM
