Edge 31000 Juice with Attitude CS issues
Old Nov 30, 2014 | 09:44 PM
somarillw's Avatar
Default Edge 31000 Juice with Attitude CS issues
:cool:
OK, so i just "finished" installing the Edge 31000 Juice with Attitude CS ....
Bunch of things happended; fist to tap my vp44 it had 4 cables instead of 2 to tap, (bought a new one not sure what type )
Then since i have a rpp100 pump on which i couldnt install the fuel pressure sensor, (had to tap the test port on the filter casing-i know not accurate readings)
Worst thing are the holes i need to drill , , for the EGT sensor i need to drill on the manifold and since i have a manual tranny another one there ob the plate.....these two things i havent done since i couldnt find anywhere the 1/8"-27 NPT i did find the drill though...
Question can i start the vehicule without the EGT and tranny sensors?, want to make suire the vpp44 was tapped correctly...
god im tired[coffee][laugh]
Old Nov 30, 2014 | 11:20 PM
97cummins's Avatar
I don't see why you cant start the motor with the egt sensor out right now. Is there a plug on the exhaust manifold you can just remove a screw the egt probe in?
The people i've talked to with manual trannies have told me you don't need a temp gauge for the manual transmissions, but that's your choice.
Old Nov 30, 2014 | 11:48 PM
somarillw's Avatar
Ho YEs about not tapping thta manual tranny; not necessary i guess, as for the EGT , if you know of one let me know , at this point i see no choice but to start drilling holes
Old Dec 3, 2014 | 05:55 PM
Rooster24v's Avatar
I am pretty sure there was not a plug to remove on your truck's manifold. Just drill and tap it, it will work perfect. I use a small punch to use so my drill bit wont wander. Just take your time. you will deffinetly want to run and EGT gauge. I would also do something about the fuel pressure gauge. You HAVE to have an accurate reading, if not the VP44 is an expensive fix.
billy_2tone
For Sale
Jun 2, 2015 06:29 AM
stewart.william.c
Feb 11, 2015 01:39 AM
Kfohne21
For Sale
Dec 23, 2014 04:17 PM
somarillw
Dec 8, 2014 09:07 PM
LawdawgSHPD
Wanted To Buy (WTB) - Used
Dec 6, 2014 06:24 PM
