Dead batteries, water pump leak
Old Nov 30, 2014 | 11:38 AM
mpcampers's Avatar
Default Dead batteries, water pump leak
Had My 2001 24v parked for a few days, normally DD but it has been cold so I parked it. We are getting ready to go south for the winter. we are not here when it is this cold.
alternator is charging about 14v with the batters down. will the grid heater drain the batteries that far if I cycle it 3 or 4 times. what other things could drain the batteries like that.
Also is there a drain on the block for the antifreeze. I have to change the water pump {leaking}
{thought I had it all ready to travel guess not}
thanks
Mike
Old Nov 30, 2014 | 12:18 PM
ramrunner01's Avatar
The grid heater shouldn't drain the battery that bad after 3 or 4 cranks I would take it and check for a bad battery my truck never has problems starting even when it's not plugged in as for the drain for the block I'm not sure I think there is a block drain but I have never drained the block in mine but I'm sure someone will chime in on the
Old Nov 30, 2014 | 04:10 PM
mpcampers's Avatar
got the water pump in. easiest I have ever done. old pump was loose, bolts were not even finger tight. installed new pump anyway.
cleaned post and grounds, is starting now. but going to charge and have the batteries tested anyway..
Old Dec 1, 2014 | 09:33 PM
mpcampers's Avatar
was able to get charging system checked, turns out the alternator is on its way out. new one going in tomorrow. hope this is all...
Old Dec 3, 2014 | 09:06 PM
What was your alternator charging at
Old Dec 4, 2014 | 08:19 PM
mpcampers's Avatar
I made some calls and found it is doing it job. when I would start the truck I would only be at 10v or so the it would go up and stop at 14+ where it should be...
The thing is We are never in the cold weather. I never had this happen before...LOL
Old Dec 4, 2014 | 08:24 PM
mpcampers's Avatar
I for got to say I installed 2 new alternator, when they tested it they did not take to account the grid heater.so we where thinking something was going wrong..
john Kuipers
Sep 16, 2015 09:37 PM
southern dieselnorth zip
May 18, 2015 01:02 AM
greasesheik
Apr 9, 2015 09:33 PM
moneypitk5
Feb 12, 2015 11:01 AM
Lawrence D. Sanders Sr
Dec 16, 2014 11:52 PM
