Power steering and brakes
Old Nov 27, 2014 | 09:26 PM
scottxmorris's Avatar
Default Power steering and brakes
Happy thanksgiving guys! I have a 2001 24v 6speed CTD my powersteering is acting up sometimes it moans and the steering wheel barely moves unless the truck is moving and other times it acts perfect i was wondering is the PSP going bad in the truck? And secondly are the brakes powered by this pump? Thanks again guys.
Old Nov 30, 2014 | 03:55 PM
98cummins's Avatar
Yes I believe a power steering pump issue affects your brakes as well. I recently had to replace that pesky seal between my vacuum pump and replace my power steering pump as well as the drive dogs between the two. i had poor brakes until after repairing and replacing this stuff then everything got much better. also discovered a pin hole on my little black vacuum line coming off of the pump so replaced that as well. You can only get one of the drive gears from cummins and i found a gentleman out in vermont i believe that makes the other one. He has you tube videos on how to do all the replacements. Hope this helps you!
Old Nov 30, 2014 | 09:25 PM
It does thanks! Will be putting a new pump on asap
Radioking1777
Jun 9, 2015 04:13 AM
ramrunner01
Jun 1, 2015 12:10 AM
01cummins4ever
Mar 20, 2015 09:25 AM
GCTownes
Oct 21, 2014 10:17 PM
1MooseheadPlease
Oct 13, 2014 05:33 AM
