HELP!! LOW BASE OIL PRESSURE ISSUE
Old Nov 27, 2014 | 12:09 AM
powerstroke4178's Avatar
Default HELP!! LOW BASE OIL PRESSURE ISSUE
I have a 04 f250 6.0, replaced hpop, and IPR. Still getting no oil pressure, no reading on dash, nor getting oil into the oil filter reservoir. I'm aware it could be low oil pressure pump, I took my relief valve out and it's scored up a bit. I'm lost on this no start. Please help
Old Nov 27, 2014 | 10:51 AM
bobfbigman's Avatar
If you are not getting oil to the filter and the relief valve is free then it is your low pressure oil pump, you will have to remove the harmonic balancer to get to it
Old Nov 27, 2014 | 11:42 AM
I removed the relief valve and cranked for 5-8 seconds and no oil came out the bore for the relief valve. Is that pretty much a guarantee its the low pressure pump? Is it worth replacing the relief valve if its scored up?
Old Nov 27, 2014 | 02:06 PM
bobfbigman's Avatar
pretty much, and yes it wouldn't be a bad idea to replace it if it is scored up
Old Nov 27, 2014 | 02:35 PM
I'll be ordering oem gears, I'll order the cover too. Do I need anything else?
soco
Jul 27, 2015 06:06 PM
robbyS
Apr 16, 2015 02:22 PM
jhprice
Mar 29, 2015 09:36 PM
Ruddedawg5.9
Mar 1, 2015 09:16 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
