Calculate MPG for Ford Diesel
Old Nov 25, 2014 | 10:33 AM
dba's Avatar
dba
Default Calculate MPG for Ford Diesel
For gas engine, MPG is usually calucalted by using MAF (Mass air flow) PID, because gas engine has fix air to gas ratio (AFR). However diesel engine doesn't have fix ratio so that method won't work.
For Ford 6.0 there is PID for Mass Fuel Desired which can be used for MPG: Mass Fuel Desired (MG/str) * Engine Cylinders / 2(for four stroke engine) * RPM * 60(to calculate fuel used per hour) / 1000(convert mg to gram) / 832(diesel density is 832g per liter)
In L/100kM:
8 cylinder engine(L/100kM): [Mass fuel desired] * [RPM] / [Vehicle speed] * 0.0288461538461538
6 cylinder engine(L/100kM): [Mass fuel desired] * [RPM] / [Vehicle speed] * 0.0216346153846154
Or in MPG:
8 cylinder engine(MPG): 8154.12 * [Vehicle speed] / ([Mass Fuel Desired] * [RPM])
6 cylinder engine(MPG): 10872.16 * [Vehicle speed] / ([Mass Fuel Desired] * [RPM])
To prevent divided by zero in the formula, you can add small number to denominator. Here is the PID file that can be used in Engine Link iPhone app:
ModePID,Description,Min,Max,Units,Formula,Header
010C,RPM,0,16383.75,rpm,((A*256)+B)/4,0
010D,Vehicle speed,0,255,km/h,A,0
221412,Mass Fuel Desired,0,100,mg/stroke,(A*256+B)*0.0625,0
,MPG(8 cylinder),0,100,MPG,8154.12 * [Vehicle speed] / ([Mass Fuel Desired]*[RPM]+0.01),0
,MPG(6 cylinder),0,100,MPG,10872.16 * [Vehicle speed] / ([Mass Fuel Desired]*[RPM]+0.01),0
Engine Link is a highly customizable, inexpensive option for monitoring all of the critical parameters on the Ford 6.0L.
Old Nov 26, 2014 | 07:15 AM
bobfbigman's Avatar
UMMM, just fill tank completely and then dived miles driven by gallons added
Old Nov 26, 2014 | 08:20 AM
RAW's Avatar
RAW
If you were to do that, you wouldn't need his $6 app! Took the link out for that little bit.
Old Nov 26, 2014 | 10:21 AM
dba's Avatar
dba
Cute.
Old Nov 26, 2014 | 10:28 AM
dba's Avatar
dba
What you get will be average MPG for a certain period.
What I wanted to share is a way to calculate instantaneous MPG and average MPG, which many folks have been trying to figure out and used to save for Ford diesel.
You can use the app to get instantaneous MPG and average MPG, and a plot.
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
bbilt
5.9L Rotary Performance
May 29, 2015 07:05 PM
Mar 18, 2015 07:30 PM
wolfnexus
Nov 4, 2014 10:04 PM
