airdog acting strange in cold
Old Nov 20, 2014 | 05:12 PM
justinsbeck's Avatar
Default airdog acting strange in cold
my airdog 150 used to make this louder kinda annoying noise and i grew used to it and it was normal and i always had about 15psi. since the weather has dropped below freezing hear in ohio my air dog only makes that noise for a few seconds when i kick it on and then it get quieter now... also i noticed that my psi drops to like 12 randomly just cruising and when idling and if i blip the throttle it will actually go back up to 15-16 psi and then will soon drift back to 12ish.... i bought a new filter and water separator but haven't swapped them yet... just wondering if anyone has any ideas... this truck has also had a previous issue of if you lift your foot of the gas to quick it sometimes stalls and needs the injector lines bled. i learned to live with that for the time being and have been told it is somewhat normal for a vp44 truck with as much done to it as mine.
any help or input would be appreciated, thanks.
Old Nov 20, 2014 | 05:56 PM
Video of the gauge(bottom)
Airdog issue:
Old Nov 20, 2014 | 07:06 PM
Baradium's Avatar
Do you add any anti gel to your fuel? If you have straight #2 diesel with no treatment it's possible your fuel is thickening up some. That would explain the noise change as well as pressure.
Untreated #2 diesel usually gels around 18 degrees.
Old Nov 20, 2014 | 11:42 PM
Im currently un gelled... its goten to be 20 degrees in the AM around here lately so i bet its thickening over night.. but it weird behavior... with it randomly regaining normal pressure or when i stab the gas it regains...
Old Nov 21, 2014 | 11:53 AM
Currently un treated fuel i mean
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:55 PM
iMixDiesel&Gas
Dec 27, 2014 09:57 PM
custom7.3
Nov 24, 2014 05:16 PM
longcarbine
Nov 13, 2014 11:33 PM
12vbomber
Nov 4, 2014 10:04 PM
