Non Wastegated HX35
Old May 9, 2008 | 11:14 AM
jkidd's Avatar
Default Non Wastegated HX35
I have a hx35/40 and ended up with a 14cm non wastegated housing. I want to sell this to a friend who is stock + edge comp. I want it to work good for him.
what boost levels will he see? Are there any problems running non wastegated? If so, does anyone have a 12cm wg housing from a 12v to sell?
Old May 10, 2008 | 12:36 AM
DB Admin's Avatar
Banned
May be laggy w/o sticks
12Cm is stock on the HX I had one but cant find it
Old May 10, 2008 | 01:32 AM
Uncle Bubba's Avatar
Non gated with the Comp also means that he's gonna have to watch his boost and keep it under control with the go pedal so he doesn't blow the turbo or a head gasket.
Old May 10, 2008 | 06:40 AM
Diesel Dummy's Avatar
Actually it works pretty good, mine never got over 40psi with rv275's with the adrenaline, lag is just a little bit more but, you will not notice it after a couple days.
Old May 10, 2008 | 07:54 PM
jkidd's Avatar
thanks, should be okay for him then if he does not go much above the HP he is at currently
Old May 10, 2008 | 09:07 PM
well i was at 360 on fuel only with the 12cm and it will take alot more now with the 14cm on it seen a drop of about 150 degrees in temps.
Old May 27, 2008 | 08:39 PM
Stangpwr71's Avatar
I wouldnt suggest it without a keen and attentive eye to the boost and egt's..
but then again i ran my hy-9 above 50 psi for 6 months with no probs
Old May 29, 2008 | 03:59 PM
dukeboy_318's Avatar
if he dont want it, pm me, i might take it off your hands
cummaprt704
May 9, 2015 04:09 PM
xmedina
Wanted To Buy (WTB) - Used
Mar 2, 2015 08:51 PM
D-350 dually
9
Feb 11, 2015 12:37 AM
BIG SOCHA
Oct 23, 2014 11:01 PM
