Still leaking coolant
Old Nov 17, 2014 | 02:58 PM
Stox5225's Avatar
Default Still leaking coolant
So I got a '97 12V and I just did the head gasket on it because I noticed I was leaking coolant in the rear of the block near the no. 6 cylinder and I had bubbles in the radiator and coolant on the oil filler cap. Swapped it out runs like a champ. However, I still have a leak! I don't see any bubbles in the radiator and for some reason it's worse than before the head gasket job. Looks to be leaking in the same general area and there's a puddle on the no. 19 head bolt. can't tell if it's a freeze plug, but if it's not that one in the rear, what else could it be??
Old Nov 18, 2014 | 01:04 PM
South Tx Coal Roller's Avatar
The head is probably warped and needs to be resurfaced.
duramax on fire
Chevy/GMC Duramax 01-04 LB7
11
Aug 14, 2017 09:51 PM
caissiel
Sep 24, 2015 05:37 PM
dieselpowa
Feb 7, 2015 10:07 PM
97f-250
Nov 23, 2014 08:08 PM
gmcmanis
Nov 9, 2014 04:49 PM
