Coolant
Old Nov 17, 2014 | 08:10 AM
ramrunner01's Avatar
Default Coolant
Hey guys it's starting to get cold here so lastnight I went and checked my coolant and in the resevoir it was a little below the cold line like maybe half an inch is it normal to lose a little bit of coolant, also the truck hadn't been ran since earlier that morning probably 8 hours so in 18 degree weather so I'm gonna top it off today haven't notcide any leaks but will be sure tonight it's not much coolant but I wanted your guys opinion hoping it's not a head gasket leak
Old Nov 17, 2014 | 08:23 AM
Sorry it was down past the add mark so I filled it to the full mark now but shes still cold did I over fill it or am I fine filling it to the full mark when it's still cold
Old Nov 17, 2014 | 12:50 PM
RAW's Avatar
RAW
The Low and Full lines are with cold coolant, you should be fine.
Old Nov 17, 2014 | 01:37 PM
So even tho I filled it to the full line with it cold it won't be over full right? And is it normal for the coolant to be at the add mark when the truck is cold?
Old Nov 17, 2014 | 03:20 PM
RAW's Avatar
RAW
Correct, both lines, Add and Full, are for coolant being cold.
Once all the air is out of the system, and the radiator is full, the coolant in the bottle should stay at the same level when cold.
Old Nov 17, 2014 | 03:33 PM
Do you think it's normal to have to add a couple cups of antifreeze over say 9 months to a year
Old Nov 17, 2014 | 03:38 PM
I also let the truck run while I was on lunch for about an hour and saw no leaks around the head just an old oil leak on the passenger rear of the head stuck my finger in it and it was old oil for sure had no scent of anyifreeze and no signs of a leak of anything the head looks like it's got new plugs and things on it
Old Nov 17, 2014 | 04:56 PM
RAW's Avatar
RAW
Personally, I don't think that is out of the normal. As coolant is half water, it can evaporate. Especially in the older trucks that have an unsealed overflow bottle.
Old Nov 17, 2014 | 05:29 PM
Ok that makes sense thanks raw I appreciate your help your always helpful
Old Nov 17, 2014 | 07:54 PM
RAW's Avatar
RAW
No problem, glad I could help.
