6.0 no start question
Old Nov 16, 2014 | 09:12 PM
Bigredpowerstroke's Avatar
Default 6.0 no start question
My buddy has a 2004.5 6.0 all bulletproofed everything and it cut out and wont atart had someone look at it said it was hpop. It just cranks and builds no oil pressure. But today we unplugged the icp and cranked her and started to get pressure. Im thinking ots the stc fittings gone bad. Let me know whag you think any info will help.
Old Nov 19, 2014 | 11:40 PM
detroitdiesel idi's Avatar
Seein how it died while driving and now won't start it sounds indeed like an hoop.
Old Nov 19, 2014 | 11:42 PM
Hpop*
Old Nov 23, 2014 | 12:18 AM
Adam65's Avatar
Pretty rare for the hpop to go bad. Go on ebay and get a 20 buck fitting and air it up. There is lots of leak points on the oil rail and stc fitting. But unless it's a huge leak it should start cold. Does it build low pressure oil on the dash Guage when cranking? If it doesn't you have a more serious issue.
Old Nov 23, 2014 | 12:52 AM
bobfbigman's Avatar
the 04.5 does not have the failure prone STC fitting, normally if it dies while driving then it is going to be one of 3 things, failed IPR valve --failed HPOP--or failed low pressure oil pump
Old Nov 25, 2014 | 03:21 PM
Just-Another-Dieselguy's Avatar
when you unplug the icp it will give a false reading to the computer, it will just show desired as actual. see if it fires up with some ether. then look at oil pressures, actual icp needs to be about 475-500 to start the engine
Cavnar
Sep 9, 2015 07:18 PM
emilio2496
Jun 29, 2015 03:00 AM
Accubuck
May 7, 2015 04:46 PM
cjgregory
Mar 31, 2015 01:45 PM
thumperf350
Jan 8, 2015 12:55 AM
