P0401 P1409
Old Nov 14, 2014 | 07:48 PM
petew's Avatar
Default P0401 P1409
I keep getting codes P0401 Exhaust Gas Recirculation Flow Insufficient Detected ,and P1409 EGR vac system leak,. The truck runs great no smoke and lots of power.
But what do I do to fix whatever is causing these codes.
97 GM 6.5 Automatic, 4X4 1/2 ton pickup
Pete.
Old Nov 21, 2014 | 11:50 AM
racer55's Avatar
Check vac line routing and look for cracked/broken vacuum lines from each vac solenoid to its next connection.
Old Nov 22, 2014 | 01:35 PM
petew's Avatar
I have done this and can't find any broken or cracked lines. New vac pump , and good vac at all locations too. I am getting the same codes on both trucks, a 97 and a 98 6.5.
Old Nov 22, 2014 | 01:58 PM
racer55's Avatar
Then you need to check the wiring to the vac solenoids and maybe replace the solenoids?
makuloco2000
Dec 7, 2014 11:15 AM
