98 12 valve 215hp injector part number?
Old Nov 13, 2014 | 07:30 PM
countryboy040993's Avatar
Default 98 12 valve 215hp injector part number?
I have a 98 12 valve auto which is 180hp truck.m wanna put new injectors in it and wanna upgrade to the 215hp stock injectors problem is i need a part number for them.. anyone have the part number for 215hp cummins injectors? Thanks
Old Nov 13, 2014 | 08:17 PM
wpg6.5's Avatar
Getting 5x12's would likely be cheaper and give you room to grow.
Old Nov 13, 2014 | 08:46 PM
Well im trying to keep the truck pretty stock and not bomb it so i can actually sell it and not get screwed and lose money like i did my last truck.. plus i can get cummins injectors for 60 bucks a piece from work so i jus wanna get the 215hp injectors and bump the truck up just a little..
Old Nov 13, 2014 | 11:48 PM
Slim Whitey's Avatar
if you can get injectors for 60, you should be able to get nozzles for 30, or even less. hell, I want the deal you get! hook a brotha up! hehe.
the only difference is nozzles. the injector bodies are the same. I'd get nozzles and get em installed and pop tested and whatnot for 15 bucks. probably save ya 100 bucks.
5x12 nozzles should be cheaper than 215 injectors.
Old Nov 14, 2014 | 07:57 AM
Yea i was thinking about it.. and yea its one of the perks for working for cummins .. and i was thinking about just getting nozzles i will just have to figure out if we even sell just the nozzle... i can look up my injector for my 180hp truck.. i jus need eithef a part number or a engine serial number off a 98 manual 215hp truck so they can use it to find the injector.. plus my truck has almost 200k miles on it so id probably be better off just replacing the whole injector so i dont have to worry abiut them going out anytime soon and having to tear it all back apart..
Old Nov 14, 2014 | 01:30 PM
Cummins tried to charge me 195 bucks per injector for stock 160hp remans for my truck.
I promptly walked out and have not been in since. that is robbery.
Old Nov 14, 2014 | 05:18 PM
Yea there prices arent the best ive seen around but working for them gets a hefty discount thats y i just wanna put in factory 215 injectors..
Old Nov 15, 2014 | 07:36 PM
I'll see about getting you a serial.
Old Nov 15, 2014 | 09:32 PM
Yea all i need is a engine serial number from a 215hp 12 valve.. that would be awesome! Thanks!
Old Nov 16, 2014 | 03:35 PM
I gotchya one. check your PMs in a few minutes.
