Egt and boost question
Old Nov 9, 2014 | 05:32 PM
scottxmorris's Avatar
Default Egt and boost question
I believe my truck has a hx35 turbo on it its a 2001 HO 24v 6 speed what is some good and cheap way to get more boost and be able to battle egts? (Note: im not looking to replace the turbo just ways to make my stock one better.) thanks.
Old Nov 10, 2014 | 12:44 AM
Just-Another-Dieselguy's Avatar
You can get a boost cooler for the turbo.
BEWARE: over 35 psi from that turbo will do no help. It turns into a hair dryer (blows hot air)
Old Nov 10, 2014 | 12:33 PM
Will a j-hook from bullydog do any good for it?
Old Nov 10, 2014 | 12:44 PM
The j-hook is designed for hy turbos, with you stating that you had an hx, I would go out on a limb and say no.
If your truck came from the factory with an automatic transmission then it has a hy charger, then it would work
Old Nov 10, 2014 | 08:48 PM
Well durn is there anything else i could do?
Old Nov 10, 2014 | 08:53 PM
Does the truck have a tuner?
Old Nov 10, 2014 | 09:10 PM
RAW's Avatar
RAW
Pinch off the wastegaste line is the cheapest, easiest way for more boost, but it's also the least controllable.
The Banks Big Head Wastegate actuator safely increases boost, but comes at a cost.
A boost elbow will give a few more psi, and is relatively cheap.
Old Nov 11, 2014 | 03:28 PM
tbirdz24v's Avatar
Like RAW said. You can pinch off the wastegate but not recommended. Adjustable boost elbow would be the cheapest way. Its not dangerous like pinching off the wastegate.
Powerstroke36
Sep 6, 2015 02:41 PM
torg73
May 11, 2015 03:08 AM
Noodle
Apr 21, 2015 06:43 PM
Crews8r
Dec 21, 2014 07:35 AM
offroad00
24
Oct 23, 2014 03:28 PM
