12v cummins fuel problem
Old Nov 8, 2014 | 02:35 PM
Antwhite19's Avatar
Default 12v cummins fuel problem
94 dodge cummins 12v stalls out and does not stay running and I check the fuel filter an it's half empty then I fill it and it starts right up and runs for a few minutes. Need help ASAP
Old Nov 8, 2014 | 04:31 PM
Just-Another-Dieselguy's Avatar
Factory lift pump or aftermarket? Sounds like you are having some fuel delivery issues
Old Nov 10, 2014 | 10:01 PM
4x4manonbroke's Avatar
What is your Idle set at ?
Needs to be 850 in D with a/c on ..
if its too low .. it will stall all the time .. keep us posted
Old Dec 23, 2017 | 07:22 AM
Antwhite19's Avatar
Sorry for no reply haven't been on here but the isue was a Rotted fuel line letting air in
Old Mar 26, 2020 | 04:58 PM
mplawler's Avatar
I have had the same problem as Jeremy. I noticed it first when pulling a trailer or going up a hill. In idle, it would stall and would not start back up until after the engine cooled. Something I have also noted is how it would appear to be over-heating. Not sure if there is a coordination there or not. I changed the fuel filter and eventually turned the idle speed up. Now that I have done that, it no longer stalls, but sometimes has a hard time starting, (It cranks but won't start). I have tried a few things, (fuel shut-off solenoid, idle speed, fuel filter and a lot of cussing) but nothing has worked. I have also taken it in to various shops where they have found nothing wrong. I like the idea of checking for a rotted fuel line and Any ideas?? Thanks!
jeremy01995
Sep 14, 2015 06:34 PM
dodgeflatbed
For Sale
Jan 27, 2012 12:30 PM
xX_CuMMiNs_Xx
Oct 25, 2011 07:28 PM
NickH
12
May 25, 2009 09:59 PM
patclark
24
Feb 17, 2009 06:38 AM
