looking for help
Old Nov 8, 2014 | 07:01 AM
dodgethat's Avatar
Question looking for help
I am getting a 2009 dodge ram 6.7 what are the mods need to get the most out of it for the money********** I know that I will need a smarty thanks
Old Nov 9, 2014 | 08:13 AM
dodgethat's Avatar
wow 126 views and not one thing not what expected here
Old Nov 9, 2014 | 11:13 AM
Just-Another-Dieselguy's Avatar
What are you looking to really get out of it. Some times to get replys you must be a little more discriptive
Mpg?
Power?
Power goal?
Budget?
Old Nov 15, 2014 | 06:20 PM
dodgethat's Avatar
egr delete and pdf something I think
Old Nov 16, 2014 | 01:23 PM
You can do all of the deletes for sure, dpf delete and a straight pipe, and may as thow in a cold air intake
Old Nov 16, 2014 | 06:32 PM
dodgethat's Avatar
can I egr delete with out a programmer or will a light come on the dash what is the dpf is that the another term for egr if not what is it and how hard is it to put a cord to the frost plug heater I just can't see it
Old Nov 17, 2014 | 03:44 PM
Rooster24v's Avatar
you HAVE to use a programmer if you want to do deletes. no way around it. the truck will run horrible and will be a pain in the a.. if you do not use a programmer.
The dpf: Diesel Particulate Filter used for pollution control
the EGR: Exhaust Gas Re-circulation. This is the cable, motor, cooler just above the exhaust manifold, also it is the tube the goes from the cooler to the intake horn. inside the intake horn is a butterfly valve.. by doing this it is feeding exhaust back into the intake of the engine. You get a ton of carbon build up inside the intake horn. Cummins recommends cleaning the entire EGR system every 67,500 miles. I did this originally and saw how much carbon and exhaust goes back into the engine and said F. that! Now i can go longer between oil changes and my truck runs soooo much better!
Do the deletes. Its a lot to swallow up front but for how much more efficient it runs its totally worth it!
Old Nov 17, 2014 | 08:36 PM
lukesdiesel's Avatar
You have a few options for your 09 Cummins. We have H&S Mini Maxx, H&S XRT Pro, Race ME, Race ME Pro and TT Tuners. Depends on your budget and your needs.
Luke
Old Nov 23, 2014 | 07:35 AM
dodgethat's Avatar
thanks for info I will be doing something soon lukediesel do you have a store
Old Nov 27, 2014 | 12:40 PM
AHolt's Avatar
If it were me I would go with efi for tuning.
