Delayed OD & TC shifting
Old Nov 3, 2014 | 11:06 PM
Alfdude1's Avatar
Default Delayed OD & TC shifting
Still trying to diagnose the transmission shifting (OD & TC).
There seems to be no rhyme or reason as to when the transmission decides to shift into OD. Sometimes @ 35mph, sometimes @ 45 and other times @ 50 mph. Sometimes if I let off the throttle completely, it will shift into OD. Once in OD it stays. I installed two LEDs that register the ground signals from the PCM for OD and TC lockup and they both light up when driving OD 1st and TC later. I contacted DTT (I have their valve body installed) and was told to adjust the TPS to 0.9vdc and it still acts the same (replaced the TPS approx 10K ago). I have installed the DTT noise filter with no change. Just had the transmission serviced with no difference.
Any other ideas? I'm going crazy.
Mike
1996 2500HD w/47RE
Old Nov 6, 2014 | 12:30 AM
4x4manonbroke's Avatar
adjust your throttle linkage .. if its off ir will mess with your tps position and such ..
also make sure your TV cable is adjusted correctly ( youtube can show ya how ) ... LOL
Old Jan 9, 2015 | 01:19 AM
Alfdude1's Avatar
FIXED IT!!!!
TV cable adjustment. I had paid a local Diesel shop to adjust, was told by shop owner it was done, NOT even close!! I adjusted it and all works well. So much for reputable shops.
taweste
Sep 10, 2015 09:16 PM
JKinni
13
Sep 5, 2015 11:09 PM
metrickjb
Jan 21, 2015 04:16 AM
SixSpeed
Jan 11, 2015 01:41 AM
Canadiancummins93
8
Dec 10, 2014 09:03 PM
