98 12 valve slight ticking when cold
Old Nov 3, 2014 | 08:39 AM
countryboy040993's Avatar
Default 98 12 valve slight ticking when cold
Ok i just noticed the other day while driving i have a slight ticking noise.. once the temp needle starts to move it goes away.. i dont hear it at idle only as slight throttle.. and after i get up to about 1500 rpm it goes away.. so basically i only hear it from 1000 ti 1500 rpm.. it sounds like its coming from the back of the engine near firewall.. i did adjust the valves about 2 months ago and replaced lift pump.. any suggestions? Thanks!
Old Nov 3, 2014 | 10:02 PM
4x4manonbroke's Avatar
OFV .. the return line is ticking .. I would make a bet that your fuel pressure is lower than 20 pis @ idle too...
Old Nov 5, 2014 | 08:38 PM
I jus replaced the overflow valve with an adjustable one i checked it 2 weeks ago and it was at i think 23 or 25 psi at idle and 30 psi at 2500rpm
Old Nov 6, 2014 | 12:14 AM
Lift pump is ticking then .. if pressure is ok .. drive it .. mine ticks too
Old Nov 6, 2014 | 09:01 AM
But what makes is only do it when engine is cold? And why only at light throttle not at idle or heavy throttle? It sounds like its coming from the #6 cylinder valves... like right on the other sode of my firewall
Old Nov 8, 2014 | 12:22 AM
cold parts .. more space until they warm up and expand ...
Old Nov 8, 2014 | 08:03 AM
Yea i gotta check it out
Old Nov 10, 2014 | 10:04 PM
try adding some lucas to your oil . I added 1 qt of the Synthetic to mine and its a bunch quieter now
Old Nov 11, 2014 | 07:40 AM
You mean lucas oil stabalizer? Or just a quart of regual lucas sytnthetic oil
RA113024
Mar 13, 2016 07:42 PM
m8snopro
Jun 26, 2015 08:40 AM
btg2820
Apr 27, 2015 12:09 AM
Baradium
Mar 9, 2015 07:15 PM
LTreis702
Feb 14, 2015 12:52 PM
