03 2500 Ram 5.9 code
Old Nov 3, 2014 | 06:13 AM
veggyoilkid's Avatar
Default 03 2500 Ram 5.9 code
I had a code thrown recently. From what I have found so far it is a gas pedal issue. My accelerator has been goofy for awhile. Anyone had this before? Any recommendations?
Old Nov 6, 2014 | 07:00 PM
FlyingDutcman's Avatar
what code are you throwing? TPS maybe? check the pedal assembly for corrosion and proper connections
Old Nov 6, 2014 | 09:43 PM
Bigg Redd's Avatar
Your throttle sensor, located at the pedal assembly may be failing. Try this.... Disconnect the connector, clean the contacts and re-connect. Maybe its just a bad/ dirty connection. A code would certainly help narrow it down tho.
Dec 29, 2014 10:20 AM
Nov 24, 2014 08:20 AM
Oct 24, 2014 02:50 PM
