Track Bar Upgrade
Old Oct 31, 2014 | 08:20 PM
motormayhem's Avatar
Default Track Bar Upgrade
My track bar is worn out and I am looking at upgrading it rather than replacing it with the stock setup. I was looking at the DT / DOR setup and the Solid Steel Industries setup.
I like the way the DT/DOR brackets are designed because it looks like the bracket is shaped to carry the load much better than some of the other styles. I also like the fact that the track bar is a straight bar making it easier to adjust.
I like the SSI setup because it uses bushings on both ends which I feel will last longer than a rod end.
  • How do these perform on a stock truck with a leveling kit?
  • Anyone have any suggestions on which one is better and why?
  • Or another option that is good?
http://sourceautomotive.biz/1994-200...ersionkit.aspx
DTP02100XHD TRACBAR KIT 94-02 STOCK TO 4" LIFT
DOR Heavy Duty Track Bar 94-02
Old Nov 1, 2014 | 01:24 PM
Slim Whitey's Avatar
the SSI kit comes out being more expensive because you also need to buy the bar itself. and you have to buy their bar.
D-350 dually
9
Feb 11, 2015 12:37 AM
JMan96CTD
Jan 24, 2015 11:16 PM
mark402001
Tire, Wheel & Suspension
Jan 18, 2015 03:17 PM
Nov 11, 2014 06:00 PM
Nov 11, 2014 02:30 PM
