need some info on 100hp injectors.
Old Oct 31, 2014 | 09:06 AM
760DAN's Avatar
Default need some info on 100hp injectors.
Hi guys i have a 96 5speed 4x4 that im starting build. I would like to put some 100hp injectors in the truck but would like some more info on them first. I haul about 6,000 +lbs from time to time. If anyone could help me out with some info or could recommend a suitable injector.
Old Oct 31, 2014 | 09:17 AM
Just-Another-Dieselguy's Avatar
We would need a list of every mod you have to give any decent options
Or you could post in the price quote section and our vendors will bid for your business
Old Oct 31, 2014 | 10:51 AM
760DAN's Avatar
The truck currently has a #100 fuel plate full foreword, afc full foreword, boost elbow, 5inch exhaust turbo back and egr blocked. Other then that the engine is stock.
Old Oct 31, 2014 | 11:10 AM
is it from Cali?
Old Oct 31, 2014 | 11:43 AM
760DAN's Avatar
Yes the truck is from California
Old Oct 31, 2014 | 12:53 PM
that makes sense then, 100hp nozzles would be a good upgrade, i am guessing the turbo is stock so with that being said the egts may be a little hot, if you do not have gauges i would get them before new nozzles. once you have the gauges and the nozzles take some time and tune the pump a little more, if you do a little reading on every function of that injection pump you will be in a better spot to play with it. once the pump is tuned right you will be able to make more power with less smoke than a poorly tuned pump. egts will also drop.
but remember, whenever anything on the engine has been upgraded the pump will need to be tuned for that setup.
Renteria1217
19
Oct 13, 2015 01:36 AM
Dslmech600
Price Quote - Request A Price
Aug 11, 2015 09:39 AM
No3l
Jul 16, 2015 10:52 PM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
