Oil through vent tube...
Old Oct 29, 2014 | 10:34 AM
12Valvepower01's Avatar
Default Oil through vent tube...
I got a 96 2500 with 560000 km on it and I'm having issues with oil coming out of the engine vent tube at 120+ Km/h if anyone knows of this or had problems with this and have found solutions ur help is greatly appreciated
Old Oct 29, 2014 | 11:33 AM
51Hudson's Avatar
Well how much oil is coming out? I know after a long hard drive I leave a orange sized spot under the truck, also I can see the side of the engine block it has a coating of oil on its side. I burn threw a quart every 2,000 miles. Hope that helps with your question
Old Oct 29, 2014 | 02:50 PM
Just-Another-Dieselguy's Avatar
It is caused from blowby. That is why the oil gets into the tube and then on the ground. If you understand basic engine fundamentals you can figure out where to check. Somehow you are getting combustion pressures into the crankcase. Try a leak down test to see which cylinder is giving you issues
Old Oct 29, 2014 | 09:39 PM
Bigg Redd's Avatar
Also, dont rule out a possible injector(s) stuck open, dumping raw fuel into a cylinder(s) and washing passed the rings and mixing/ diluting the oil in the crankcase. This will cause the oil/fuel mixture to overfill the crankcase to which it will spill out of the vent tube. Check your oil level. If it is waaaay over the full mark, your likely "making oil" through the event decribed above. If its low, your likely losing it through excessive blow-by. Just tossing it out there..........
Old Oct 29, 2014 | 09:42 PM
I have had that happen to me personally. This does not sound like the case
Old Oct 29, 2014 | 10:58 PM
did u ever find out what it was mine only does it when i go above 120km/h at 2000 and up rpm if i run lower speed n rpm its fine. right now its still stock but I'm wiry on doing stuff to it and f**k it up more.
Old Oct 30, 2014 | 02:40 PM
Slim Whitey's Avatar
boost pressure goes up.
cylinder pressure goes up.
old rings combined with tapered cylinders results in a poor seal at high cylinder pressures.
Don't worry, I have the same thing. although my engine leaks from all orifices (even after a full reseal, I still coat the bottom on the truck), so it's difficult to tell.
I get minor (read: next to nothing) out of the blowby tube, and more from the dipstick tube actually. then again my dipstick collar is broken.
Old Oct 30, 2014 | 03:45 PM
It is not that abnormal.
i meant i had an injector hang open... twice
Old Oct 30, 2014 | 04:09 PM
I was more explaining why your truck does it (oil out the vent tube) at higher RPM (vehicle speed has little to do with it, beyond potential engine load)
Old Oct 30, 2014 | 04:10 PM
Bigg Redd's Avatar
That happened to me as well. 2 injectors hung open, as a matter of fact. My engine was puking diluted oil through the vent tube BIG TIME. Coated the entire undercarriage. At least now it wont rust under there....
