Amsoil Visit - Amsoil
Fluid Change
Old May 8, 2008 | 01:10 AM
2500HeavyDuty's Avatar
Default Fluid Change
Enough to change out all fluids except for engine oil on a 01 chevy silverado 2500HD duramax/allison 4x4
Old May 8, 2008 | 06:38 AM
Heath's Avatar
Authorized Amsoil Dealer
For the diffs, 7qt will do. I'll assume 75W-90 for both now. The tcase has been an item of discussion. It calls for ATF, but many are using the 5W-30 motor oil. 2qt to replace or 3qt to overfill thru the speed sensor. We also have the pump to make it easier to get the fluids in. For the tranny, you have two choices, either the ATF or the torque-drive. Your model year called for the the dexron 3 product. Either of these will work. You're probably familiar with it, but torque-drive is a replica of the Transynd. Sometimes I'm asked which I would use. I like the ATF. It's a newer, improved product. Meets the demands and even runs a little less..but either is fine.
Also, how do you plan on doing the tranny? A full flush will take 13-14qt. If just doing a pan drop, 8qt will do.
Let me know tranny fluid choice and qty. Also which fluid for tcase and qty. As for diffs, as mentioned, I'll assume 75W-90 unless you might be thinking 110 in the rear.
ONce I have those vitals, I'll shoot you a price.
Thanks,
Heath
Old May 8, 2008 | 07:21 AM
Marine's Avatar
Good post Heath!
Old May 8, 2008 | 01:23 PM
Thanks,
Heath
im doing a transmission flush and torque drive would be nice. the transfer case im going to put ATF and 2 quarts also. Rear diff 110
i think that covers what u want to kno?
Old May 8, 2008 | 02:16 PM
Heath's Avatar
Sounds good. I fogot to mention that the torque drive is fine for the tcase as well. That way you only have to order one type for both and a case of 4 gallon should be just right to do both.
I'll price that along with 2qt 7eW-90 for the front and 4qt 75W-100 for the rear.
thanks,
Heath
Old May 8, 2008 | 03:06 PM
DB Admin's Avatar
Banned
Heath your the Greatest !
Old May 8, 2008 | 07:34 PM
Heath's Avatar
Appreciate the kinds words. I must also tip my hat to RSWORDS. He made a referral for me today. A business aquaintance of his asked him where he could get some AMSOIL and he referred the gentleman to me. It's things like that that make this site special.
Thanks Bobby!!
Old May 8, 2008 | 11:16 PM
thanks
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
PA 24valve
Aug 31, 2015 07:39 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
MBFD 592
Jan 1, 2015 11:37 PM
Bigredpowerstroke
Dec 19, 2014 05:18 PM
