Front end problems
Old Oct 23, 2014 | 06:17 PM
Cumminsman911's Avatar
Default Front end problems
So right now I'm driving and at 70 miles an hour on the interstate, the front end shakes a little bit just enough for me to notice that it shaking. I can feel in the steering wheel and you can feel it through the floor that the front end is shaking. I just replaced the lower ball joints the track bar and driver side tire rod not too long ago. Anyone else have any ideas? Ideas it be greatly appreciated. Thanks.
Old Oct 23, 2014 | 07:28 PM
4x4manonbroke's Avatar
have the tires re balanced .. have them look for defects in tire treads ... or jack up front end and spin tire and see if one tire is out of round .. I have this happen @ work ( Double Coin tires non the less ) ..
Old Oct 23, 2014 | 07:58 PM
JBearSVT's Avatar
Steering box brace?
Old Oct 24, 2014 | 11:20 PM
Idler arm
Pin arm
manny things can make this happen .. start by having tires re-balanced
Old Oct 25, 2014 | 06:56 PM
Slim Whitey's Avatar
way too many things can contribute to the steering issue you speak of.
it's a matter of rebalancing tires (better yet, rotate them after rebalancing them) and then going through the front end and thoroughly checking it.
Old Oct 26, 2014 | 05:41 AM
JBearSVT's Avatar
I would actually rotate them before rebalancing them, and see it the vibration moves around (or just plain goes away).
Old Oct 26, 2014 | 01:13 PM
actually. . .that is a stellar idea.
isolate which side the vibration is coming from, and put that tire on opposite end diagonally. So the right front would go to the left rear, etc.
Old Oct 26, 2014 | 03:56 PM
01dodgeboy's Avatar
Is your truck lifted.?
Old Oct 30, 2014 | 05:42 PM
I had them rebalanced last Saturday and the problem hasn't gone away. I'll check front end tomorrow when I'm not on the interstate! Thanks for the help fellas!
Old Nov 1, 2014 | 04:07 PM
any more updates ?
shingi
Off Roading
Sep 30, 2015 11:17 AM
tbirdz24v
Aug 22, 2015 06:41 AM
jonnyb2crazy
Mar 26, 2015 10:23 PM
Slim Whitey
Wanted To Buy (WTB) - Used
Mar 3, 2015 06:15 PM
2FordStrokers
Jan 11, 2015 09:40 PM
