Lift pump actin up
Old Oct 20, 2014 | 03:21 PM
12VALVECOUNTRYBOY's Avatar
Default Lift pump actin up
Back in June I had a new timing case put on (KDP a distaster) and while the shop had the truck apart, the lift pump decided to take a crap. So they put a new one on it, all was well after that. Well about a month ago it started funny, kinda took a little longer for it to crank followed by a couple seconds of rough idle then it smoothed out. Well I just put a new fuel pressure guage on it. I am idling at 5 psi and at WOT I get to about 22-25 psi. I know this isn't wnough. Sound like a lift pump problem? If so I'm gonna get the shop warranty to cover that. I just don't want it to eat my injection pump up.
Old Oct 20, 2014 | 06:47 PM
Just-Another-Dieselguy's Avatar
Running it low on fuel pressure is not recommended, but it is not a vp pump. It won't fry the first time it gets less than 5psi. It should be alright for the time being
Old Oct 21, 2014 | 07:39 PM
4x4manonbroke's Avatar
I would check an make sure your return line isnt cracked .. I had this exact problem ... I cut my line short, and installed a Tork Tek OFV .. now I can Bump the key and she fires right up .. MPG is up, power is up smoke is down .. all together, single best mod thus far ( next to the 5" straight Exhaust !!)..
twinturbo12v
5.9L CR Performance
Nov 26, 2015 02:06 AM
landon025
Sep 8, 2015 09:21 PM
Renteria1217
Apr 16, 2015 11:38 PM
klein444
Feb 21, 2015 10:33 AM
moneypitk5
Feb 12, 2015 11:01 AM
