Coolant bypass
Old Oct 19, 2014 | 07:34 PM
JustAnother_cummins_guy's Avatar
Default Coolant bypass
Anybody on here know if you can do a coolant bypass on the good ol 12 valve without using the rear freeze plug like maybe teeing off if the temp sensor? I don't have any temp problems but I am getting up in the hp and I know the stock cooking system is only meant to handle around 350 hp and I don't have any current problems with the rear plug and with something like that why fix it if it ain't broke?? I do however have the plate from haisley machine in case it does go. I'm just looking for some ideas to get me by for now until I get time to rebuild it and do it all right
Old Oct 19, 2014 | 11:07 PM
97cummins's Avatar
.I think it is possable yes.i think i know someone that has it done on their 12valve.
i'll do some checking with them,
Old Oct 19, 2014 | 11:31 PM
4x4manonbroke's Avatar
in between the last two Bead bolts on passenger side there is a Frost plug in the head .. you would pop that out and NPT thread it and install a 90* Brass fitting with as big of a hose fitting as you would like .. can also use a ball valve as it will make it more difficult to warm up on cold days
Old Oct 20, 2014 | 11:03 AM
I did think about that but I would think it would be too much stress on the plug. Or is it like a thread in plug that I've never noticed ?
Old Oct 20, 2014 | 01:40 PM
Just-Another-Dieselguy's Avatar
There is no threads behind the plug, you would have tho thread it yourself
Old Oct 20, 2014 | 02:05 PM
Thread the plug or thread the hole in the head?
Old Oct 20, 2014 | 02:39 PM
thread the hole in the head, the plug will go MIA and you will install a npt fitting that you can put your hose onto. and like stated above, you can install a ball valve to shut the bypass system off to help warm the engine up on colder days
Old Oct 20, 2014 | 09:09 PM
I wonder what size pipe thread that would be cause we have all the fittings and hoses at the shop and I was thinking a thermostat valve instead of a ball valve
Old Oct 21, 2014 | 01:45 PM
I think its 1/2" Npt ? cant remember .. I will look into it ..
Old Oct 23, 2014 | 05:18 AM
94 12valve's Avatar
The bypass relieves excessive pressure being built up, so you would want to use a pressure valve not another thermostat valve.
If you are worried about it on a hot street truck personally I would pull your current thermostat and drill three 1/8" holes in it.
