05 6L died cranks no start
Old Oct 18, 2014 | 01:07 PM
Tyler_302's Avatar
Default 05 6L died cranks no start
Was driving down road hit a pretty bad bump truck died turns over but does not start had it towed to shop mechanic checked for codes nothing came up checked the high pressure oil and was only getting 45 psi so he changed the ipr valve still won't start so he changed the hpop now and it still won't start now he's thinking that it might be the low pressure oil pump any other ideas
Old Oct 18, 2014 | 03:15 PM
Just-Another-Dieselguy's Avatar
Get another mechanic. You cannot just throw parts at something and engine.
So was it desired icp being 45psi, or was it just the actual icp? Make sure the FICM is plugged in tight as well..
Old Oct 19, 2014 | 08:50 AM
Tyler_302's Avatar
It was actual pressure, and now he says there is nothing at all after the new hpop is installed
Old Oct 19, 2014 | 10:37 AM
What was the desired pressures at?
Old Oct 19, 2014 | 07:20 PM
Adrenaline junkie's Avatar
I'm thinking low pressure oil pump too, bump was just unfortunate coincidence. You better test low pressure oil pump first, and check for shavings in oil filter housing.
Old Oct 22, 2014 | 06:46 PM
Tyler_302's Avatar
So after all that it was number 6 injector blew top oring out, swapt injector out and now it runs perfect.
Old Oct 22, 2014 | 07:08 PM
That can do that for sure!
Congrats on having your truck back.
Rusher48
Jul 2, 2020 08:39 AM
moose2j
Jun 21, 2015 12:36 AM
Rusher48
Feb 20, 2015 05:19 PM
southernbelle14
6.0L Performance
Dec 29, 2014 10:53 AM
Cloadkicker
Nov 9, 2014 02:33 PM
