Hard to start
Old Oct 16, 2014 | 07:27 PM
dodgeboy30's Avatar
Default Hard to start
I have a 2001 dodge ram 3500. The truck is hard to start. I have to bump the starter at least twice before the truck will start. I have replaced the one return line that connects to the back of the head to the T block. What else could be the problem??????
Old Oct 17, 2014 | 07:55 PM
Just-Another-Dieselguy's Avatar
What is the fuel pressure to the ip, if you do not have a fp gauge you might as well buy yourself a new ip. It is something that needs to be monitored.
Fuel more than likely is draining back due to either a bad vp/ip or a bad lp
Lp-lift pump
Ip- injection pump
Vp- well I hope you know that one
Old Oct 18, 2014 | 05:57 PM
dodgeboy30's Avatar
if i park the truck nose down hill it will start right away. didn't know if any of my return lines was the problem or not. who ever had the truck before me replaced a section of the one line running to the tank with a rubber line.. cause i can smell diesel sometimes after the has been run.
Old Oct 18, 2014 | 08:40 PM
What line is it? Return, feed?
Downhill and it starts fine shows a drain back issue. Is it a factory lp?
94turbostroker
Feb 26, 2016 07:51 PM
Dcbb93
Nov 30, 2015 10:18 AM
Blanton
Apr 15, 2015 06:29 PM
dfish001
Mar 30, 2015 03:07 PM
trab123
Feb 9, 2015 09:44 AM
