Steering Wheel Alignment
Old May 7, 2008 | 07:38 AM
CumminsW250's Avatar
Default Steering Wheel Alignment
What would cause the steering wheel to be misalligned? They guy I bought my truck from says he had the truck alligned and yet the steerring wheel still won't like up the way it is supposed to. The truck doesn't pull and the tires are wearing evenly so I believe what he said.
Old May 7, 2008 | 10:28 AM
2500HeavyDuty's Avatar
probably when somebody turned the wheel when replacing the gearbox would be my best bet. What kind of steering system is it?
My dad did the same thing when i was replacing his pitman arm and now hes got to deal with a crooked steering wheel. Truck don't pull and tires wear evenly.
Old May 7, 2008 | 10:41 AM
LOGANSTANFORTH's Avatar
adjust your drag link, it will bring it back straight....
Old May 7, 2008 | 10:58 AM
If I remember right that is the part the previouse owner told me was the problem. But it isn't adjustable. Maybe I'm thinking of the wrong part.
Old May 7, 2008 | 03:37 PM
GO OVRIT's Avatar
The factory draglink is not adjustable. There were some companies making adjustable ones. Is the truck lifted at all? Or sagging? If the wheel is all that bothers you, you can pull it off the column and turn it. If your truck turns farther one way than the other, then moving the wheel won't help that.
Old May 7, 2008 | 04:01 PM
Whit's Avatar
Site Mascot
without the adjustable drag link ya hafta pull the wheel and re-clock it
Old May 7, 2008 | 05:14 PM
Can you actually do that? I know that some vehicles it only goes on one way.
Old May 7, 2008 | 10:03 PM
GO OVRIT's Avatar
You should be able to. I've turned mine.
Old May 8, 2008 | 07:01 AM
GRI's Avatar
GRI
it is possible that it happened when the alignment was done. it happened to several of my vehicles.
Old May 8, 2008 | 07:21 AM
I will probably be doing that this weekend. I just dont like that I can't see all my guages because part of the steering wheel is in the way.
ramrunner01
Jun 1, 2015 12:10 AM
Boostaddiction
May 4, 2015 06:28 AM
BubbaDT55
Apr 12, 2015 10:47 PM
6.5dieselman
Feb 26, 2015 04:45 PM
sweetv8s10
Oct 7, 2014 09:47 PM
