help
Old Oct 12, 2014 | 12:39 PM
ken petty's Avatar
Default help
I have a 2000 dodge with the 24 valve 5.9 diesel. It's doing some crazy stuff! I recently moved to utah from Washington state, and my truck has not been the same. When I take off, I have no power and it seems to take a lot for the Turbo to get going and when it does a lot of black smoke comes out. Also pressure is building up in my fuel tank, and my rpm gauge stops and goes as it pleases. Any ideas??
Old Oct 12, 2014 | 09:48 PM
97cummins's Avatar
The only thing i could think of is the altitude and pressure difference since you moved to utah.
Old Oct 12, 2014 | 09:55 PM
ken petty's Avatar
I thought that also, but shouldn't the computer adjust itself? I also disconnected the batteries for about an hour, that should have reset everything!!
Old Oct 13, 2014 | 04:33 PM
wolfriver's Avatar
Sounds like more then 1 problem to me. I have heard of an injector copper gasket start to leak and allow pressure from the engine compression to bypass and get back to the tank. I would pull the valve cover and make sure the injector retainers are tight first. then if not that I would pull injectors looking for a bad seal. and replace with new seals. that's just my 2 cents.
good luck.
Old Oct 16, 2014 | 04:08 PM
Just-Another-Dieselguy's Avatar
sometimes a copper washer can leak causing combustion pressures to get into the fuel return, it can get bad enough to the point when you will plug a fuiel filter every 100 miles. it will look almost like algae in the fuel system. i recommend installing new o-rings and copper washers to the injectors asap. i can almost promise the issue goes away. its also a good time to install new injectors. they are cheap enough for that truck that it never hurts to try something new.
if you pm me i have a few sets laying around with about 500 miles on them
