hotrod vp44 and edge issues
Old Oct 11, 2014 | 09:36 AM
justinsbeck's Avatar
Default hotrod vp44 and edge issues
Hello, let me first start out by saying ive had a first gen 12v for awile but i just picked up a 1998.5 24v built twin turbo truck. now the truck once had an older edge on it but it was removed by the second to previous owner because the previous owener didnt have enough cash to get that along with some other things. i just last night put an edge juice with attitude on and the truck currently has a hotrod vp44 fead by an airdog 150. all was well heading down my road to test everything and once i hit level 5 i gunned it and took off like a bat out of hell but suddently i relized once i started to slow down that my truck was acttually not running anymore so i had to get dragged back down the road to my house. now im aware that this isnt the first time this issue has happened. its common to get air in the vp44 when you use an edge but with a stock pump... i have the stock pump plus an airdog on a sump. i cant seem to figure out how i could have airlocked and or killed my fancy $1700 vp44 wheni have everthing required to never let it go dry. i havent had a chance to try and bleed the system and i hope i didnt fry my vp44 but with that aside i need to no if any one has any ideas to how i could have had this issue even though i have a bottom tank sump feeding an airdog AANNDD the stock pump. any input would be GREATLY appreciateed.
Old Oct 11, 2014 | 11:03 AM
yjay's Avatar
Did you happen to see your fuel pressure when you were romping on it?
Old Oct 11, 2014 | 12:06 PM
i just bled the system and got her running..thank god !... i went to the back yard and did a bunch of launches on level 5 on the edge... i seemed to be running between 13-15 psi off the airdog the whole time then boom same problem... i bled the 134 lines again and shes running again... i dont understand where the air is coming from.
Old Oct 11, 2014 | 02:39 PM
im also having issues with my built goerend trans...its a stage 3... when i do a very hard boosted launch or a launch in 4x4 it launches great but then wont shift into the next gear and then it wont shift right for awhile and then goes back to normal after a while... i have no idea what thats all about either...
Old Oct 14, 2014 | 06:23 PM
ill update this for anyone that may come by it in the future with the same original problem.... my twin turbos where pushing so much my over sized injectors where getting air literally shoved up them and causing air to get into the injections lines when i got off it to soon when i was on extreme tuning. and as far as the tranny... i just simply broke that...
Old Oct 14, 2014 | 07:38 PM
01cumminsboy's Avatar
I do not have a fuel pressure gauge nor have I checked it. What sucks is my diesel shop is backed up tell the 25th. My date to get new injectors and lift pump.( ignore this, wrong thread)
Old Jan 18, 2016 | 12:15 AM
CaseyV93's Avatar
Hey I just upgraded my pump to the hotrod pump. I'm running 100 horse sticks with 150 airdog but I'm using the draw tube not factory tank sump. What injectors are you running. I'm only running stock charger with the wicked wheel so I don't think I'll run into the airlock issue I'm just trying to get some insight from some guys who are running the hotrod pump
Big Bill
Price Quote - Request A Price
Mar 19, 2015 11:13 AM
somarillw
Dec 15, 2014 12:00 AM
somarillw
Dec 8, 2014 09:07 PM
somarillw
Dec 3, 2014 05:55 PM
