Governor spring issue
Old Oct 11, 2014 | 02:26 AM
Tj8826's Avatar
Default Governor spring issue
I installed 4gsk the other day and my truck is still shifting around 2300 at WOT, if I shift it manually it'll get to higher rpms just not when in drive. Is this normal for an auto.
Old Oct 12, 2014 | 05:54 AM
JBearSVT's Avatar
I think probably 90% of my posts here are saying something to this effect these days, but since nobody else has chimed in yet: sounds to me like your TV cable is out of adjustment. If it was a fueling issue, I don't think it would go over 2300 no matter how you shift it.
Old Oct 12, 2014 | 12:30 PM
Tj8826's Avatar
I've adjusted the cable in both direction and it hasn't really done anything
Old Oct 12, 2014 | 03:34 PM
JBearSVT's Avatar
The adjustment starts at the tranny end. Regardless, that's all I got. If it spins higher manually than in drive, then IMO the problem isn't the GSK.
Old Oct 12, 2014 | 03:42 PM
Tj8826's Avatar
I agree I just didn't know if anyone had experienced this, I'll keep adjusting and see if it helps
Old Oct 12, 2014 | 04:07 PM
JBearSVT's Avatar
If it doesn't change anything then it's probably not the problem either, but it's all I got.
Old Oct 13, 2014 | 07:00 PM
Tj8826's Avatar
Well... Fixed the problem... Bracket for the fuel shut off solenoid was off by a little.. Pretty stupid
Diesel_Daddy6.0
Nov 12, 2015 09:33 PM
Diesel_Daddy6.0
Sep 23, 2015 03:12 AM
dskewes14
Sep 14, 2015 09:19 AM
JKinni
13
Sep 5, 2015 11:09 PM
Oct 23, 2014 08:10 AM
