charging system problem
Old Oct 9, 2014 | 11:59 PM
Jreeb's Avatar
Default charging system problem
hi everyone I have been fighting a losing battle with the charging system on my truck, it only acts up when it's below 50 degrees, then the voltage gauge with jump back in forth between 9 volts and 14 volts and the lights flicker with it. the parts that have been replaced ecm, alternator, battery's, checked connectors. I've gone threw it from front to back and even had it at 4 different dealerships and still can find the problem plz help thanks.
Old Oct 12, 2014 | 10:02 PM
97cummins's Avatar
That sounds it may be your grid heater cycling. Does it only do it after you start the motor?
Old Oct 12, 2014 | 10:22 PM
Jreeb's Avatar
yep it only does it when i start the motor and only when it's cold out. if it's above 60 degrees it will not be erratic.
Old Oct 20, 2014 | 01:31 PM
jigabop's Avatar
LMAO
Every year without fail!
This is NOT a problem with your truck! Perfectly normal behavior!!!!
It is the intake grid heater cycling.
That intake grid heater uses about 2600w of power... (about 220A) which is far more power than the stock 136A alternator can keep up with. This is the one and only reason your truck has TWO BATTERIES. it does not need two batteries to start... It needs two batteries to stay running and start with that huge power draw from the grid heater during the winter months.
The grid heater will cycle any time the temp is below 60* F outside during key on/starting. it will stop cycling after something like 5 minutes, or when the vehicle exceeds 20MPH, whichever comes first..
Stop wasting your money replacing perfectly good parts. your ECM cycles the grid heater on and off because of the huge power draw... it cycles it off to prevent dropping below a certain voltage level, and to prevent the wires from overheating, and then cycles back on/off in timed intervals..
all cummins trucks do this.
If you don't like it: get a 240A alternator, delete the grid heater, or get a gas motor...
burndiesel
10
Feb 7, 2023 01:15 AM
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
Adell Bob
Mar 23, 2015 12:39 AM
Mopar Mike
Oct 6, 2014 07:51 PM
