6.7 dpf delete "see dealership code"
Old Oct 9, 2014 | 08:31 AM
stillcummin's Avatar
Default 6.7 dpf delete "see dealership code"
I'm doing a DPF delete for a customer. He had some damage to his DPF harness I repaired. Truck was not going into regen and filled the DPF. He now has the "exhaust filter full ,see dealership" – code. He now wants to remove it .My question is, after I install the kit and Foolers,How do Rid code?
Old Oct 9, 2014 | 09:15 AM
Motorops's Avatar
FormerVendor
If you are installing a Tuner that is DPF delete it will shut the codes off in the system. Look into a EFI live set up for the truck and all those codes will be shut off and you'll have nothing to worry about.
Old Oct 17, 2014 | 09:00 PM
The kit uses foolers
Old Oct 17, 2014 | 09:16 PM
Just-Another-Dieselguy's Avatar
Then the dealer must take the code away, you can try unhooking the batteries, taking the pos/neg cables and tape them together, let sit overnight and re hook.
That may work but no promises!
Old Mar 15, 2015 | 12:10 PM
cards91's Avatar
Default dealer code
Try removing cat a dpf dont't put fooler in leave pressure sensor in, start truck after 30 seconds give it a few pumps on the throttle. It will go into regen mode, watch percentage drop. then put foolers in and pressure swith simm. 2008 6.7 worked for me.
Old Jul 17, 2015 | 11:01 AM
brand97's Avatar
what kind of tuner works the best??? Thanks
Old Aug 14, 2015 | 08:01 AM
BigTexRam's Avatar
Tuner Smarty, Smarty JR. , EFI Live , H&S mini maxx. Race me .
Old Feb 18, 2016 | 08:13 PM
Viper9762's Avatar
Need Help on a maxiforce dt one of the pos international motors can anyone tell me if you can delete the egr coolers with no issues on running due to having the regen system please help putting in a 10k motor and my coolers are plugged and to the tune of 3k I don't want to replace them
Strae 1
Chevy/GMC Duramax 2011 LML
16
Jan 10, 2016 10:27 AM
sleepysubie
12
Jun 23, 2015 02:21 PM
willyam
Price Quote - Request A Price
May 19, 2015 10:20 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
leaderbeanjr
For Sale
Jan 20, 2015 01:22 PM
