Fuel pressure gauge question
Old Oct 8, 2014 | 10:26 AM
scottxmorris's Avatar
Default Fuel pressure gauge question
Im trying to install a fuel pressure gauge the gauge has a electric sending unit im not quite sure where or how to install it...im also install a raptor lift pump at the same time.
Old Oct 8, 2014 | 11:10 AM
gh0stman's Avatar
are you changing the fuel lines or are you using the stock fuel lines? If you are changing fuel lines get a quick connect that will fit in line with the new fuel line. If you are running stock line mount it up at the VP.
Old Oct 8, 2014 | 02:10 PM
Ok im using stock lines but what will i need to connect the electronic sending unit to the vp?
Old Oct 8, 2014 | 02:14 PM
gh0stman's Avatar
Banjo bolt and snubber valve. This will connect into you VP. You should be able to find these on google.
ctjkelley
Jun 3, 2015 06:01 AM
RatsMC
May 4, 2015 05:25 PM
robbyS
Apr 16, 2015 02:22 PM
moneypitk5
Feb 12, 2015 11:01 AM
cummins Pride
Oct 6, 2014 11:28 AM
