Another auto OD problem
Old Oct 4, 2014 | 06:05 PM
450r racer's Avatar
Default Another auto OD problem
95 with lockup and I need help. My truck used to shift fine and lock up at 50. After I had a whole new throttle cable linkage put on it won't even shift into 4th until 61. I can flip my switch and it would put it into 4th then I would have to pump it all the way to 62 to get into OD. Today, it wouldn't go into OD until I drove redline for about 5 miles. Now it won't go in at all. I've adjusted the cable, and TPS full both ways and it didn't even make it shift sooner or later. I need help fast and don't have time to look through 500 forums. Any help would be appreciated
Old Oct 6, 2014 | 09:45 PM
4x4manonbroke's Avatar
TPS is going on the fritz .. or you need to adjust the IP linkage ( not cable .. the threaded link ) ..
Old Oct 7, 2014 | 12:05 AM
450r racer's Avatar
How do I adjust that?
450r racer's Avatar
I mean more along the lines of tighter vs looser
Old Oct 8, 2014 | 11:04 AM
there is a specific way to adjust the linkage ... Check out Youtube ..
.. this is for the TV cable adjustment
There are a ton of vids .. just rome through them ... you will get the Idea
Old Oct 18, 2014 | 06:58 PM
450r racer's Avatar
Ok here's an update. I put a new plug on the tps, I put a new control sensor on the tranny. And yet it will still not go into 4th at all. Unless I flip my switch and it sends it into 4th. Any help?
Old Oct 19, 2014 | 11:38 PM
TCM gounding or O/D gounding issue ...
burndiesel
10
Feb 7, 2023 01:15 AM
jeremy01995
Sep 14, 2015 06:34 PM
Dec 4, 2014 04:00 PM
1ATony
1A Auto Parts
Dec 1, 2014 09:34 AM
flyers.nhl
Oct 31, 2014 04:33 AM
