01 speedo cruise control odometer not working
Old Oct 3, 2014 | 11:01 AM
jcottonoir's Avatar
Default 01 speedo cruise control odometer not working
Truck is an 01 6speed HO So I changed the sensor on top of the diff and it didn't fix it HELP!!! Everything in the wire lume looks good and my abs light is on too kinda stuck any info wld be awsome
Old Oct 6, 2014 | 05:59 AM
gh0stman's Avatar
Have you hooked a code reader up to it?
Old Oct 6, 2014 | 03:04 PM
jcottonoir's Avatar
Ya a nice snap on one I bought it for work thank god I had it but it just through over spool codes and I tryed to run an abs scan but for some reason it won't run the scan
Old Oct 6, 2014 | 03:17 PM
jcottonoir's Avatar
Shld I check the ABS sencers It wld explain the ABS light but not the speedo and odomater not working but idk im not savy with electronics
Old Oct 7, 2014 | 04:02 AM
gh0stman's Avatar
My clip was broken on mine and the previous owner ziptied the connection. I did the same and it solved my issue.
Old Oct 7, 2014 | 08:04 AM
tworks's Avatar
0pen loom right up to frame rail. I have had lots that look ok but you need to tug test each wire every inch to see if there is a break inside the wire insulation. good luck
pt
burndiesel
10
Feb 7, 2023 01:15 AM
JBearSVT
Jul 9, 2015 06:16 PM
jdnetx
Jul 2, 2015 07:38 AM
kryz9903
Jan 3, 2015 07:00 AM
Oil Igniter
Nov 27, 2014 05:56 PM
