Truck won't start
Old Sep 30, 2014 | 08:28 AM
DylanBrito's Avatar
Default Truck won't start
My 97 12v isn't wanting to start when I try to do so the starter just clicks. It has two new batteries, new alternator, new starter all the fuses are good. And It's not cold I live in Texas so its not wanting to start when It's hot out.
Old Sep 30, 2014 | 10:26 AM
4x4manonbroke's Avatar
Starter solinoid is toast or the starter motor is seized up ..
Might try to smack it with a dead blow hammer ..( DONT USE METAL HAMMERS ) you wont get your core charge if the casing is dented !!!
Old Sep 30, 2014 | 12:17 PM
DylanBrito's Avatar
What causes it to seize up? Also my battery gauge is stuck at 12.
Old Sep 30, 2014 | 12:33 PM
You may need to jusp the batteries for a bit ....
Dirt, sand, Moisture, ..... all the above
Old Sep 30, 2014 | 12:50 PM
DylanBrito's Avatar
Can the starter solenoid be toasted even though It's new?
Old Sep 30, 2014 | 11:32 PM
YUP happens all the time ..
Might wanna check to make sure there is power @ the trigger wire when the ignition is in the start position .. sometimes the relay goes bad too ..
Old Oct 1, 2014 | 08:13 AM
DylanBrito's Avatar
I also failed to say that it'll run for a couple days then just stop then again for a few more days then it just completely stop last Saturday. This has been going on for about two weeks now.
Old Oct 1, 2014 | 10:07 AM
Starter is likley not good
Old Oct 1, 2014 | 10:51 AM
DylanBrito's Avatar
The starter is least then a week old.
Old Oct 1, 2014 | 10:52 AM
DylanBrito's Avatar
*less.
