12 Valve will not start
Old Sep 29, 2014 | 05:47 PM
6_in_a_row's Avatar
Default 12 Valve will not start
My killer dowel pin fell out and I had to get a new timing case and when I did this I messed up the injection pump timing. I should be able to just take off the injection pump gear and twist it a little right? Or is it more complicated than that?
Old Sep 30, 2014 | 10:18 AM
4x4manonbroke's Avatar
WAYYYY more complicated my friend ....
Your gonna need to pin the Injection Pump , Then set enging to TDC with the crank pin ( right under the IP) .. then tighten the IP gear back down to torque spec ( make sure you use brake cleaner on the IP shaft and the inside od the gear other wise your likley to have the timing slip ) ..
OR
Take it to a shop and make sure it gets done right the first time ..
Old Sep 30, 2014 | 02:21 PM
6_in_a_row's Avatar
I have set the the engine to TDC. How would I know when the injection pump is in the right spot? Or does the pin for the injection pump only go in when it is set on the 1st cylinder and in correct timing?
Old Sep 30, 2014 | 11:31 PM
yes the pin for the IP only goes in on the #1 Cyl .. setting it this way ensures factory timing ..
When you are almost gear to shaft .. make sure to tighten the bolt with an agressive snap just before the bolt is tight .. then Ping the gear lightly with a small punch and a light hammer .. ( only do this with a small amount of force ) .. dont pyle drive it ..
then Torque the bolt to spec on the IP gear bolt ..
PeteBug
Jun 11, 2015 12:16 PM
Baradium
Mar 9, 2015 07:15 PM
ronstop
Feb 26, 2015 09:48 AM
RayRay4991
Feb 23, 2015 07:45 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
