Need help
Old Sep 29, 2014 | 02:55 PM
Godfrey21's Avatar
Default Need help
I have 2005 6.0 powerstroke, it has new arp head studs, new turbo, new heads, egr delete, all new injectors, 4 inch exhaust from turbo back, new hpop, and new oil cooler. I'm having problems with it blowing white smoke and can not figure it out. When I start it it's fine and it's fine in neutral but as soon as I put it in gear it will start smoking only on take off though. Any advice will be greatly appreciated thanks
Old Sep 29, 2014 | 04:09 PM
Just-Another-Dieselguy's Avatar
Do a compression test.
Is it white smoke as in coolant?
or white smoke as in Raw Fuel?
Old Sep 29, 2014 | 04:13 PM
Godfrey21's Avatar
Okay I will have that done, it's fuel smoke thank you
Old Sep 29, 2014 | 04:20 PM
Yeah it sounds like it could be down on compression. ive seen alot of damage happen to those engines. i hope for your sake this is something i have no idea about!
Old Sep 29, 2014 | 04:43 PM
Godfrey21's Avatar
Yes I had one injector go bad on me and because of that one injector I've dropped over $5k in it, melted the piston cracked the head and the pieces of the piston went through my turbo and blew it up, wasn't good thanks for the info I'll def be doing a compression test
Old Sep 29, 2014 | 04:55 PM
5k? thats not to bad when it comes to a 6.0
Old Sep 29, 2014 | 05:00 PM
Godfrey21's Avatar
No it wasn't too bad from what I hear other people pay
Old Sep 29, 2014 | 05:01 PM
I send out bills on those trucks for 10-15k all the time!
Old Sep 29, 2014 | 05:04 PM
Godfrey21's Avatar
Wow that's crazy, I must have got lucky Im pretty sure I won't buy another 6.0 after I'm done with this one
