transmission issues
Old Sep 25, 2014 | 05:55 PM
MBFD 592's Avatar
Default transmission issues
when my truck first goes into overdrive the transmission tries to downshift almost like the converter is locking and unlocking. it only does it between 45 and 55 mph when I am driving easy. once I am over 55 mph the truck runs fine. it did this once before a couple of times then went away, now I cant engage my overdrive until I am over 50 mph. has anyone had this problem before and how did you fix it ?
Old Sep 26, 2014 | 05:08 AM
gh0stman's Avatar
I have had this problem and it was fixed with a BD noise filter, it helps take the noise out of the alternator signal that the TC reads as GO CRAZY. Just make sure when/if you install this that you go buy a can of battery terminal cleaner and sealer. This will solve the issue. To install it takes about 10-15 minutes.
dwmeehan
Jan 29, 2025 12:13 PM
Max713
Apr 17, 2015 01:18 AM
02Stain
Feb 17, 2015 10:21 PM
Polaris04
Dec 1, 2014 08:27 AM
TheDirtyDozen
Oct 1, 2014 10:09 AM
