97 dually to single wheel flatbed
Old Sep 22, 2014 | 09:35 PM
kubiak's Avatar
Default 97 dually to single wheel flatbed
pick of my dually to single wheel flatbed.
Old Sep 22, 2014 | 09:39 PM
kubiak's Avatar
Default last month pic before building flatbed
pick of truck before i did the flatbed conversion
Old Sep 23, 2014 | 04:26 PM
4x4manonbroke's Avatar
Where did you get the FB ? That thing sure looks sexy with that on there .. my truck is just like that only 2 wd ... what was the cost ? PM me with info please
Old Sep 23, 2014 | 09:04 PM
kubiak's Avatar
heres another pic. it cost me about 500 bucks in material to make the flatbed. it was easy to make but it was over 100 degrees the week i was building it that made it seem hard!
Old Sep 26, 2014 | 06:26 PM
kubiak's Avatar
i used 2by5 inch square tubing to make the outside rectangle then used 2by4 inch square tube to do the 4 inside rails so when i used the sheetmetal to lay on top of the bed it sat inside about 3/4 below. i went 76 inches outside to outside and 8 feet front to back to fit the single wheel.i used 2 inch square tube to run front and back to lay on the trucks frame rails. that set the bed at a nice level.then ran 8 four inch channel off the 2 inch rails that run along top of the truck frame at about 5inches long each to connect to the frame holes. the front section i used 2 inch square with sheetmetal leftover from the floor of the flatbed that i had cut from a 10 foot by 71 inch piece. i had the shop cut 2 feet out of the 10 foot sheet so i could use 8 feet for the top and 2 foot for the front rail.now i have bedliner on the inside of the floor of the bed which looks great!
Old Sep 26, 2014 | 06:32 PM
NICE ... I will be using these measurments to do something like this I think ...
We shall see ...
Old Sep 26, 2014 | 07:45 PM
dezeldoc's Avatar
What did you do with the front wheel adapters? if you want to sell them let me know.
Old Sep 26, 2014 | 09:51 PM
kubiak's Avatar
darn i gave them away already. sorry.
Old Sep 26, 2014 | 09:52 PM
kubiak's Avatar
We shall see ...
let me know if you need more info.
Old Sep 26, 2014 | 11:52 PM
Oh I will .. U can count on it !!!
