oil leaks!!! please help!!
Old Sep 22, 2014 | 07:56 AM
lovitt07's Avatar
Default oil leaks!!! please help!!
i have two 12v trucks one is a 94 automatic 2wd other is a 96 5spd 4x4 both trucks run great have plenty of power both trucks leak oil like there is no tomorrow. the 94 hauls a 40ft trailer the 96 hauls a 48ft trailer we fix leaks weekly go out on a run and come back to fix more leaks why is this and how can we stop it!
Old Sep 22, 2014 | 09:52 AM
Kbnecessary's Avatar
What keep giving problems
Old Sep 22, 2014 | 10:18 AM
lovitt07's Avatar
On the 96 we have replaced valve cover gaskets, vaccum pump seals, timing pin o-rings, rear main seal, cam plate now it looks like I have to replace the injector pump o-ring and front timing cover gasket are we going to have to continue to do this because of the hauling and having to run these engines so hard to climb mountains and run 75mph on the interstate
Old Sep 22, 2014 | 10:19 AM
lovitt07's Avatar
Its like every time we fix a leak it creates a new one
Old Sep 22, 2014 | 10:30 AM
lovitt07's Avatar
Keep in mind these are stock trucks not turned up nothing done at all
Old Sep 22, 2014 | 12:30 PM
4x4manonbroke's Avatar
Blow bye ...
Crank case pressure can be caused by several things ..
#1 .. Most overlooked also ... Turbo seals .. can push pressure into the oil return causing crankcase pressure ..
To Diag, this symptom -
Pull the oil return line . put a short piece of hose on the return from Turbo, place the hose in a 3 gallon bucket .. have someone start engine and build some boost .. it the hose it below the oill and the turbo is the issue .. it will cause a bunch of bubbling, if you just get a little bit of bubbling and lotts of oil .. Blow bye from cylinders is more likley ..
Old Sep 22, 2014 | 01:00 PM
lovitt07's Avatar
ok will check that shortly i have heard that the 12v needs a second venting system such as valve covers with breathers or a second vent tube? as i said before both trucks have plenty of power i will check the turbo return tonight to make sure.
Old Sep 22, 2014 | 01:14 PM
I would check the turbo's first .. then move on to further venting ... also .. while engine warm ( @ opperating temp ) .. @ idle pull the oil fill cap ... if you see excessive puffing thats pulsating .. it will be cylinder blow-bye ..
Old Sep 23, 2014 | 07:27 AM
lovitt07's Avatar
checked turbo checked out good i believe the vent tube is stopped up because even with reving the engine it still just barely has any pressure coming out of it
Old Sep 23, 2014 | 04:25 PM
I would pull the oil fill while its running @ temp .. see what you get there .. if its puffing hard its blowbye .. if its just smokin a bit . then its ok .. but what is it pushing out gaskets ??
Durtyd09
Nov 11, 2015 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
soco
Jul 27, 2015 06:06 PM
coors_man_2005
Dec 15, 2014 10:23 AM
97f-250
Nov 23, 2014 08:08 PM
