47rh issues
Old Sep 21, 2014 | 07:53 AM
drewm's Avatar
Default 47rh issues
I've got a '66 F100 that I swapped a 12 valve into, and after burning up a getrag, I rebuilt a 47rh (my 4th or 5th to rebuild) and swapped it in. It worked great for about 10,000 miles. I pulled the motor to do a p pump swap and took the trans out too, sealed off all the ports, and covered it to keep moisture out. I've got everything back in and now it will only go in reverse, no forward gears at all. Reverse engages perfect, RPM's drop like they should and it doesn't slip. What do y'all think could be causing this? Any help is appreciated.
Drew
Old Sep 21, 2014 | 11:23 PM
4x4manonbroke's Avatar
Sounds like your having a VB issue .. I would pull the pan and inspect for possible debris ...
If you can post a pic of the pan findings ...
Old Sep 22, 2014 | 09:44 AM
drewm's Avatar
I'll pull the vb on Friday. I was hoping it wasn't a VB issue. I jacked up the rear end to see what was happening in all gear positions and it creeps in neutral, so i'm thinking vb also. Put it in drive and second, nothing changes. Put it in 1 and the wheels stop spinning. I'll post pics when I get it all pulled out.
Old Sep 22, 2014 | 12:31 PM
Sounds like it stuck in R and 1st .. does it have a Trans brake ? Could be sticking if so ..
Old Sep 22, 2014 | 12:38 PM
drewm's Avatar
No trans brake. Hopefully it's just something sticking in the vb. It's been sitting for a few months. I appreciate your help man.
Old Sep 22, 2014 | 01:11 PM
May wanna also go ahead and do a band adjustment while you there also .. just to ensure that it dosent need to be done again soon down the road
Old Sep 22, 2014 | 05:10 PM
drewm's Avatar
Will do. Shouldn't be too bad out of adjustment. It's only got 10,000 since it was replaced. I'll post pics of what I find.
Old Sep 22, 2014 | 06:35 PM
Old Sep 29, 2014 | 07:11 AM
drewm's Avatar
Pulled the VB and did an air pressure test on the trans. Blown rear clutch seal. Time for rebuild number 2.....
Old Sep 29, 2014 | 03:05 PM
Oh man .. yeah that will do it for sure .. No pressure to apply clutches ... Kinda counter productive ..
